Geo Redundant Squidex instance
Will Managed Server or Managed Cluster offerings facilitate?
The goal is an Azure East/West geo-redundant Squidex instance.
I am currently researching Azure solutions that will solve East/West regional failover and potentially allow for East/West active/active load balancing.
We would need the system to be fully functional in while operating from either region, but not necessarily both regions simultaneously.
My current thoughts involve active/read-only east/west Squidex instances, connected to MongoDB Atlas East/West Clusters, and Squidex implemented as east worker, west readonly, switching to squidex west as active in a failover scenario, with MongoDB being a constant.
Thank you.
I guess this should work. You need 2 ELK clusters and then a cross region load balance to connect to both services .But it will be very expensive, I guess around 2-3k per month. If you are mostly reading a CDN will be much cheaper, as mentioned before. In my experience 90% of the use cases are super simple and you can live with stale data for these cases.
