Hello Sebastian,
I currently need to use a notification system in an app, and Notifo seems a great choice, however I´m having difficulties generating de bearer token for using in https://notifo.easierlife.com API.
I can query and use the API if I copy the Bearer token header from “https://app.notifo.io” and paste it in a script.
After some digging I found this route “https://app.notifo.io/connect/token” can give me the token however I cant send this through a script because the header values always change.
Is it possible to generate the Bearer token using your API and if so how?
Best Regards,
Tiago Marante
