Is there a way to force a full rerun of rules on all schemas?
Let’s say i’ve setup a webhook rule, but need to do a full load before receiving incremental changes, is it possible?
When you self host you can rerun the rule enqueuer. But there is a hard coded constant to ignore old events:
You could provide a PR to move this setting to the rule options.
Thanks for the reply, my suggestion would be to add a button to push all models current state through the rules and to force a full sync. Is that your idea as well ?
The button is already there for self hosting:
You can just click the “Restart” button for the RuleEnqueuer to replay all events, but this ignores all old events, therefore we just need the setting.
I only need the latest version of the object, so i guess that would fit my need
Hi Sebastian
I tried what you suggested, but getting this error here:
MongoDB.Driver.MongoCommandException: Command find failed: Executor error during find command :: caused by :: Sort operation used more than the maximum 33554432 bytes of RAM. Add an index, or specify a smaller limit..
at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol`1.ProcessResponse(ConnectionId connectionId, CommandMessage responseMessage)
at MongoDB.Driver.Core.WireProtocol.CommandUsingCommandMessageWireProtocol`1.ExecuteAsync(IConnection connection, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Servers.Server.ServerChannel.ExecuteProtocolAsync[TResult](IWireProtocol`1 protocol, ICoreSession session, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.RetryableReadOperationExecutor.ExecuteAsync[TResult](IRetryableReadOperation`1 operation, RetryableReadContext context, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.ReadCommandOperation`1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.FindCommandOperation`1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.FindOperation`1.ExecuteAsync(RetryableReadContext context, CancellationToken cancellationToken)
at MongoDB.Driver.Core.Operations.FindOperation`1.ExecuteAsync(IReadBinding binding, CancellationToken cancellationToken)
at MongoDB.Driver.OperationExecutor.ExecuteReadOperationAsync[TResult](IReadBinding binding, IReadOperation`1 operation, CancellationToken cancellationToken)
at MongoDB.Driver.MongoCollectionImpl`1.ExecuteReadOperationAsync[TResult](IClientSessionHandle session, IReadOperation`1 operation, ReadPreference readPreference, CancellationToken cancellationToken)
at MongoDB.Driver.MongoCollectionImpl`1.UsingImplicitSessionAsync[TResult](Func`2 funcAsync, CancellationToken cancellationToken)
at Squidex.Infrastructure.MongoDb.MongoExtensions.ForEachPipelineAsync[TDocument](IAsyncCursorSource`1 source, Func`2 processor, CancellationToken cancellationToken) in /src/src/Squidex.Infrastructure.MongoDb/MongoDb/MongoExtensions.cs:line 183
at Squidex.Infrastructure.EventSourcing.MongoEventStore.QueryAsync(Func`2 callback, StreamPosition lastPosition, FilterDefinition`1 filterDefinition, EventPredicate filterExpression, CancellationToken ct) in /src/src/Squidex.Infrastructure.MongoDb/EventSourcing/MongoEventStore_Reader.cs:line 187
at Squidex.Infrastructure.EventSourcing.PollingSubscription.<>c__DisplayClass1_0.<<-ctor>b__0>d.MoveNext() in /src/src/Squidex.Infrastructure/EventSourcing/PollingSubscription.cs:line 45
Could you advice me what i need to do?
This has been solved in the current dev version.
Ahh okay cool thanks ! do you know when there will be a release version of it? or potentially something that we can do short term?
You need a ascending index on the timestamp field.
