- [x] Bug report
I use generated client with NSwag (similar to what is used internally for .net SDK from time when I build it). After some time i try to generate new client and even if I download swagger.json version which is not in “flat” docs/link. It totally broke my app and I cannot provide “simple” reproduction step (yet) but I notice that in generated client there is XXXFlatDataDto class are use in XXXContentDto which a believe should use XXXDataDto
"data": {
"description": "The data of the content.",
"nullable": false,
"$ref": "#/components/schemas/BlogsFlatDataDto"
Non flat swagger.json is provided as it originally was.
- [x] Self hosted with docker
Version: 6.5.0.0
