- [x] Used code blocks with ``` to format my code examples like JSON or logs properly.
When trying to sync out our content from one application to another we are facing the following issue.
if I use “sq export <schema_name> --format=JSON” I got the file but when I import it into the other app I have the following error:
ERROR: Singleton content cannot be created.
HTTP Response:
Squidex.ClientLibrary.Management.SquidexManagementException`1[Squidex.ClientLibrary.Management.ErrorDto]: Singleton content cannot be created
in the other hand, trying to sync out all our contents (as we have many to go one-by-one) using “sq sync out -t contents <folder_name>” I have this other error
Exporting admin (0)… succeeded.
ERROR: Squidex.ClientLibrary.SquidexException: The app, schema or entity does not exist.
at Squidex.ClientLibrary.Utils.SquidexClientBase.EnsureResponseIsValidAsync(HttpResponseMessage response) in /home/fmac/hackerman/github/squidex-samples/csharp/Squidex.ClientLibrary/Squidex.ClientLibrary/Utils/SquidexClientBase.cs:line 106
We were expecting to migrate all the content from one application to another as they will belong to different environments of the application
App Name: oral-surgery-cms and oral-surgery-prod
- [x] Cloud version
