First 50 results taking too long for one million and a half records
  • [ ] Bug report
  • [ X ] Performance issue
Squidex fresh install. I’ve a one million and a half records on a schema. When I click on it on the content UI, it takes about 4 to 6 minutes to appear but if I search ONE word(even if its still loading the first 50) it gives the results immediately.
If I search for more than ONE word, it takes like 20 seconds or more to load and it gives innacurate results with the default full text search.
To return accurate results in less time.
  • [ X ] Self hosted with docker (macbook air 2017, intel i7, 8GB RAM)
  • [ X] Chrome (desktop)
We are investigating 2 issues here:
1. Why is the normal query so slow?
2. The quality of the full text search.
2.1. Why does it take so long for 2 words?
2.2. Why are the results for 2 words bad?
We should skip 2.2. for now and focus on the performance issues first.
Here are a few things you can do:
Hi Sebastian! Thanks for your time and support. I really love your work!!!
I did what you say, turned on the profiler logs and mongodb profiler, then stop/start the container but now I have a new issue: localhost throws a 502 error and the squidex/mongodb logs shows something like a background running process trying to populate the db.
As a side note, I imported a CSV with python and POST’ed successfully through the REST API.
Now that the container services are starting, it seems like it’s trying to “POST” some remaining data(or all data) from somewhere(the python script finished his work and it’s not running) but I don’t know why.
I’ll PM the logs due that it has some sensitive information on it.
