Is there a way to filter the request to a specific language?
We thought it might be possible to use GraphQL but it doesn’t look like we can, based on what we’ve seen/tried. Did we miss something? Is there any other way to achieve this behavior? Thanks!
We support 13 languages in our app, and because of that, each post contains 13 different translations. This results in a high traffic (for example, this month we had 70GB out of the 100GB that is available in our plan). We’re concerned that once we add this content to another product/website, this will increase.
We want to limit the traffic by requesting per specific language rather than all of the languages at once or if you have other ideas how to reduce the traffic usage?
I really doubt that the traffic comes from the content itself. It is more likely that it comes from some assets. You can download the logs and analyze them using the CLI.
If you have traffic problems I also recommend to use caching, especially for things like headers and footers.
But about your answer.
In GraphQL you have to define the languages you want
e.g.
query {
findXContents {
id
data
title {
en <--
