Hi Squidex Support,
I have a schema with reference field and would like to filter for entries with specific id and entries which have no reference set. Is there a way to do this?
Best regards,
Jens Lehmann
Hi Squidex Support,
Best regards,
Jens Lehmann
Sure, you can do it with
Filter by id
`$filter=data/myReference/iv eq ‘123’
and no refes
$filter=empty(data/myReference/iv) // Coming tomorrow
I get the following error: An unknown function with name ‘empty’ was found. This may also be a function import or a key lookup on a navigation property, which is not allowed.
-> Tomorrow this is available?
Best regards,
Jens Lehmann
Yes, it is already implemented but not deployed yet. I will deploy it tomorrow around 1pm probably.
Hi Sebastian, is this function already deployed? Best regards, Jens Lehmann
Not yet, I had an unplanned Meeting.
Sorry, I had a problem with the build server yesterday. It is deployed now.
