Not sure if I’m posting this in the right forum, but I’m looking for a way to filter through elements with an optional EndDate field. I need elements that either have that value empty or greater than current date. The latter I’ve managed but I can’t seem to take empty records into account. Here’s the OData query I’m using:
data/EndDate/iv eq null or data/EndDate/iv ge {currentUtcDate}
I’ve tried putting all 0’s instead of null, empty string etc. But I’m not getting the desired result. Couldn’t find the proper way to do this with OData either. The JSON I’m receiving when not filtering for EndDate doesn’t even have EndDate field on the data property that I could check the value of.
I’m thinking of putting a default value of 31/12/2099 in there so that it is not optional but there has to be a better way.
Add empty date field to your content, try to query for elements with said field empty.
- [x] Cloud version
