Field Rules for User Role Not Working
  • [ x] Bug report
When trying to utilize the Field rules for user role it seems the rule is not applying the rule correctly.
Fields disabled, hidden, etc based on user role specified
  • Navigate to schema, click more, and scroll to Field Rules section
  • Add a new rule to disable the field
  • use a rule: user.role === ‘UserRole’
  • Field is NOT disabled for user role
  • use a rule: “user.role === ‘UserRole’”
  • Field is disabled for ALL user roles
  • [x ] Self hosted with docker
Version: 5.0.0
  • [x ] Chrome (desktop)
  • x[ ] Firefox
  • [x ] Edge
Similar to [IMPLEMENTED] Conditional field according to user
Is this in latest version?
It is not implemented in your version.
What version does have it and I can see if we can upgrade.
Thank you
I am not sure. It was a one liner I think and therefore not part of the changelog.
