- Bug report
- Performance issue
When I configure hide rule for any component type field, this rule also called for every nested field, but with different “data” object
Because of this, a hiding rule like data.condition !== ‘a’ works correctly for data that has a “condition” field. But for nested fields this condition always returns true
“sub-value” field should not be hidden by the rule. The rule should not be called for it.
I think problem in this code https://github.com/Squidex/squidex/blob/856709e667814402aeba251e5d7b882df92478f4/frontend/src/app/shared/state/contents.form-rules.ts#L180
This function calls with “path” = “value.sub-value” and I assume that this function should clear “.iv” part, but returns “value” as path. Because of this, the rule intended for “value” field twice.
"type": "Component",
"fields": [{
"name": "condition",
"properties": {"fieldType": "String", "editor": "Radio", "allowedValues": ["a", "b"]}
"name": "value",
"properties": {"fieldType": "Component", "schemaIds": ["77023cb5-7b95-4fe7-9dc8-35882a1b1fcc"]}
"fieldRules": [{
"action": "Hide", "field": "value",
"condition": "(() => {console.log(data); return data.condition !== 'a'})()"
"type": "Component"
"schemaId": "77023cb5-7b95-4fe7-9dc8-35882a1b1fcc",
"fields": [ {
"name": "sub-value",
"properties": { "fieldType": "Number" }
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.9.0
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
