[SOLVED] Fallbacks failing for empty strings after editing
  • [ x ] Bug report
Fallbacks seem to fail after populating and then later deleting the contents of a field.
Field should fallback if empty.
  • Have languages en and sv, where sv is optional and fallbacks to en.
  • Populate a text field, eg. heroHeading, for both languages. Save.
  • Remove the text in heroHeading for sv. Save.
The api response for heroHeading is an empty string "" instead of the value of en.
Reproduced with a regular string input and an input with the CKE editor. In the case of the CKE editor, the value was <p>&nbsp;</p>
  • [ x ] Self hosted with docker
  • [ x ] Chrome (desktop)
The question is: How to distinguish between an empty string that is there on purpose and a empty string because the content has been unset?
Perhaps the solution would be to add a clear button somewhere to the UI?
Mm, I see your point there. In my opinion, I would see empty strings falling back as a behavior that is more expected. Especially since there isn’t a way of seeing in the ui whether an empty field will/won’t fall back (for the moment, at least). I’d also imagine the use cases for wanting an empty string are fairly sparse.
A clear button sounds like a great solution :+1: Perhaps only show it if the field is actually populated so there is a way detecting whether it’s an empty string or not?
Lets say you have a ad banner for a website and you don’t want to show the banner for a language or the banner is not ready yet. Then it would show the fallback version instead, in another language.
Hi, I have solved it in the master branch by always converting empty string to undefined in the UI
Awesome, thank you! Honestly haven’t had the chance to check out the change yet, but it sounds promising :heart:
