- [ ] Used code blocks with ``` to format my code examples like JSON or logs properly.
Hi, I am setting an on premise environment and I would like to know if there is any other way to export configuration data without specifically install the cli for example like api or including the cli in the installation of squidex.
Thanks
- [x] Chrome (desktop)
- [x] Safari (desktop)
