Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
Used code blocks with ``` to format my code examples like JSON or logs properly.
Regression (a behavior that stopped working in a new release)
Bug report
Performance issue
Documentation issue or request
When importing a schema (using json) with values in the "“fieldsInLists” array, an error appears within a red banner like so:
Are you sure that you are on 7.0.0.0? I think the UI does not show the minor versions. Your docker tag is more relevant. And your broken JSON would help, because I do not have issues with data.id
Im not sure what you mean by docker tag? we have not had to setup docker containers as we are using the cloud version. I cant post our full json, however I will reproduce the error in a test app that doesnt include company IP and will get back to you. We are busy right now, so it might take a couple of days.
Thank you for all the help you provided Sebastian! I’ll return with an example shortly.
