Error uploading animated svg
When uploading certain animated SVG files to Squidex (Cloud), the upload fails with the following validation error:
“Validation error. The SVG is malicious and contains script tags.”
The SVG files are assets provided by third-party providers and are uploaded as-is, without any manual editing on our side.
Valid SVG files that do not contain executable scripts should upload successfully, or Squidex should provide more detailed feedback about which SVG elements or attributes are being flagged.
Common SVG features such as masks, filters, and styles should not trigger a false-positive security error.
  1. Attempt to upload an SVG asset received from a third-party provider.
  2. Squidex rejects the file with:
Troubleshooting performed
  • Cleaned the SVG using SVGO (npx package) → upload still fails.
  • Gradually reduced the SVG by removing images, filters, and styles, leaving only basic structure and a mask → upload still fails.
  • Removing the element from a simplified version allows the file to upload.
  • Removing the from the original SVG with all assets present still results in the validation error.
  • Removed style blocks to avoid alternative style parsing → no change.
  • Tested both the original SVG and the SVGO-cleaned version with the same results.
This suggests the error is caused by a combination of SVG elements, rather than a single invalid or malicious tag.
Further removal of elements allows upload but breaks rendering, making manual sanitization impractical.
I can provide examples of the .svg files
I would need the svg to check it. But squidex has a whitelist of properties and elements that are allowed and if anything is not in the list it is permitted.
sent files in via gist.github in DM
URLs can only start with https and http. No data urls are allowed at the moment.
