[SOLVED] Error exporting schema using CLI tools
  • [x ] Checked the logs and have provided the logs if I found something suspicious there
  • [x ] Bug report
I am attempting to export the schema from the DB using the CLI on OS X and am receiving the error below which makes me wonder if these tools work on OS X since obviously these dlls will not be anywhere on my Mac.
Command ➜ sq schemas get schema > schema.json
ERROR: Could not load file or assembly ‘System.Diagnostics.Tools, Version=4.1.1.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’. The system cannot find the file specified.
I’d expect the schema to be exported.
On OS X, install the CLI tools.
Connect to a cloud instance using instructions on the connect tab.
Use CLI to use that app.
Attempt to export schema as json and notice error.
  • [ ] Self hosted with docker
  • [x ] Cloud version
  • [ ] Chrome (desktop)
  • [x] N/A
Honestly I do not have a Mac. Which version do you use? The self contained version?
cli-v4.1
Downloaded the OSX version.
osx-64.zip or dotnet.zip?
osx-64.zip. Sorry for the confusion.
Can you try this: https://www.dropbox.com/s/i8h3qkgmd3xni76/sq?dl=1 ?
With that I successfully exported the schema.
Thanks.
Great, then I will change the build process tomorrow.
Hi, I have updated the build process, can you check the newest binaries?
Just to close the loop here, this is working.
Install Squidex CLI on OSX Mac
  1. $ brew cask install dotnet-sdk
  2. $ dotnet tool install
  3. $ dotnet tool install --global Squidex.CLI --version 4.3.0
Using Cli: https://docs.squidex.io/02-documentation/developer-guides/automation-tools
  1. $ sq config add [APPNAME] [CLIENT_ID] [CLIENT_SECRET]
  2. $ sq config list
  3. $ sq config use [APPNAME]
  4. $ sq schemas list
  5. $ sq schemas get [SCHEMA1] > [SCHEMA1].json
If something does not work, you can always remove the app and re-add again.
$ sq config remove [APPNAME]
This just works fine
