At the moment schema scripts will trigger in management ui only if the event type is:
- Create
- Change
- Delete
- Update
Do you know any easy way to change the squidex code locally to allow *Query schema scripts to trigger also for management ui? It does not be an issue if management portal features will have problems, I just need to prevent content queries for some users.
It would make my day. Thank you.
