I am running squidex in a local machine using docker. The upsert request to elastic search is not working.
You can check the Error logs here.
And the elasticsearch params here
Any action like content-updated, published should trigger a upsert request to elasticsearch and insert/update the information in elastic search.
- Download the docker-compose and .env file from squidex-docker
- Replace the docker-compose.yml file with
version: '2.1'
services:
squidex_mongo:
image: mongo:latest
volumes:
- mongo:/data/db
networks:
- internal
restart: unless-stopped
squidex_squidex:
image: "squidex/squidex:dev"
ports:
- "5000:80"
hostname: ${SQUIDEX_DOMAIN}
environment:
- URLS__BASEURL=${SQUIDEX_PROTOCOL}://${SQUIDEX_DOMAIN}/
- URLS__ENFORCEHTTPS=${SQUIDEX_FORCE_HTTPS}
- EVENTSTORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- STORE__MONGODB__CONFIGURATION=mongodb://squidex_mongo
- IDENTITY__GITHUBSECRET=${SQUIDEX_GITHUBSECRET}
- IDENTITY__SHOWPII=true
- IDENTITY__PRIVACYURL=http://research.squidex.com/privacy.html
- REBUILD_APPS=true
- LETSENCRYPT_HOST=${SQUIDEX_DOMAIN}
- LETSENCRYPT_EMAIL=${SQUIDEX_ADMINEMAIL}
- UI__ONLYADMINSCANCREATEAPPS=True
depends_on:
- squidex_mongo
volumes:
- squidex_assets:/app/Assets
networks:
- internal
networks:
internal:
driver: bridge
volumes:
mongo:
driver: local
squidex_assets:
driver: local
- update the .env file to
SQUIDEX_PROTOCOL=http
SQUIDEX_FORCE_HTTPS=False
SQUIDEX_DOMAIN=localhost:5000
SQUIDEX_ADMINEMAIL=user@example.com
SQUIDEX_ADMINPASSWORD=user@123!
SQUIDEX_GITHUBCLIENT=
SQUIDEX_GITHUBSECRET=
SQUIDEX_GOOGLECLIENT=
SQUIDEX_GOOGLESECRET=
SQUIDEX_MICROSOFTCLIENT=
SQUIDEX_MICROSOFTSECRET=
- run
docker-compose upand access the app fromhttp://localhost:5000 - create a rule for elastic search and fill the required information:
Host: http://localhost:9200/
Index Name: app_name
- Now create new content and check the log for elasticsearch log.
- [x] Self hosted with docker
- [x] Chrome (desktop)
