Editor to design the expressions in schema triggers
#1
Loving the webhook feature so far… however, I must say I’m a fan of ealier versions of the UI/UX. It is way simpler to understand and to work with.
I totally see the need for the more recent UI/UX changes but I think both UI/UX should be available.
LIke:
Not as much as the above UI:
#2
What exactly do you mean? If you would add the schema you can define a condition.
#3
I’m referring to the actual UI. Before there were nice checkboxes for the events, now I have to manually type these in, in condition-like statements. That is not good UX. :slight_smile:
#4
I know, but it is much more powerful as the examples show. My resources are limited and if I would have to create a UI for all the features that are possible with expressions I would be busy for the full year.
But I was thinking about an expression generator.
In you example you can just write event.type != 'Archived'
#5
Absolutely, totally understandable.
I can manage, but might be harder for others.
Can we at least add a list of all the events in the docs? Because that was initially the first question that I had. And add a code snippet for lets say this view:
Currently I’m just listening for ALL events. Slows down my app but I can get things done faster :stuck_out_tongue:
#6
Then just leave the expression empty :wink:
#7
Oh, I can do that? That’s great. Will try it then, thanks.
