When i edit a text with the source code view
and i create a tag like
<a to="https://digitalfinance.teamsystem.com/incassa-subito" target="blank">Incassa Subito</a>
and i save, when i open again the source code the tag is like this.
<a target="blank" >Incassa Subito</a>
I’ve done things like this usually, but from some days it’s no more possible
- [ X] Cloud version
- [ X] Chrome (desktop)
I would use “href” instead of “to”
I now, but we used a custom html parser, and i don’t understand why i cant write everything i want in a textfield…
It is just the behavior of the rich text html editor. When you use the source code editor and close it, it parses the html and removes errors. Otherwise it would have a lot of issues keeping invalid html intact when making changes in edit mode.
When you want to use a custom html editor, I would just use the simple html editor or text field.
Yes but untill few day it worked and now we have a lot of content lost.
If i type the tag in the simple html editor the “<” and “>” is convertend in the html code, so we need again to update our parser.
I have not changed something with the rich text editor. I am pretty sure about that. Which editor do you use?
I use markdown, html, richtext and now no one is working like time ago.
Then I have really struggle to understand the exact problem. Can you provide me a step by step description how i can reproduce it?
Ok,give me some time to investigate and provide you with all the information.
Thanks
We have solved by edit our parser.
Thanks!
Okay, but I still don’t understand what the source issue is.
