Just wondering if it’s possible to add a label to the UI when using components inside a schema, as you add more components it becomes difficult to know which one you want to edit quickly.
I know this works with traditional “array” with component inside. It would be nice to have this feature also on components directly so you don’t have to add an “item” then add “component”.
Proposed implementations
