- [x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [x ] Documentation issue or request
- [ x] Self hosted with docker
- [ x] Chrome (desktop)
Hi Sebastain
We have a requirement explained below.
We have reference schema category, with field type having options: low/mid/both
Now this schema is used as reference to dropDown in two other schemas.
Schema 1 : has all low and both type caterogy options (from category) in dropdown
Schema 2: has all mid and both type category options (from category) in dropdown.
Is it possible to implement it in Schema 1 & Schema 2 like this ?
Where dropdown values are filtered based on type field ?
Thanks
