- [X] Documentation issue or request
It’s a bit unclear about how to use UpsertAsync / CreateAsync etc
It would be nice to have some official documents
Before we have an official document, I would love to share what I found so people in the future can save some time to figure this out.
Usage
This is for anything to write into Squidex.
Let’s say the Schema has 1 field called test (localizable)
The Objects should be
public class Test : Content<TestData>
public sealed class TestData
public CmsEnString Test { get; set; }
public class CmsEnString
public string En { get; set; }
GetAsync
For reading data, there are 2 solutions.
Either to use the above Objects or assign a context like
QueryContext Context = QueryContext.Default.WithLanguages("en").Flatten()
With this context, data object will be like
public string Test { get; set; }
The above information can be discovered from https://docs.squidex.io/02-documentation/developer-guides/api-overview/api#json-queries
Hope this can help others to save some time
