I got the same issue as below described when the squidex behind a proxy server.
I tried to change enforceHttps to true. but it doesn’t work, it just keeps redirecting
What is your baseUrl setting?
Your proxy server must set X-FORWARDED-PROTO header
Thanks!!!
HI Seamys. We have excatly th same problem. We have set X-FORWARDED-PROTO in the config for th site on the server with:
X-Forwarded-Proto
RequestHeader set "X-Forwarded-Proto" expr=%{REQUEST_SCHEME}
What did you use?
Thanks
Tiaan
I was thinking about using static values for hostname and protocol from the base url and just ignore all these headers.
This would make it much easier. But I am not sure if I miss any security issues. Right now I just follow best practices.
