Disabling fallback language
Is there a way to disable falling back to a language in the cloud version of Squidex?
I am trying to show the user that their language is not available but I am unable to verify if that’s the case when it always falls back.
Thanks in advance.
Not right: No.
But i can introduce a flag for you.
That would be perfect.
Is this something you have planned to do? If so, when can I expect it to be present?
Thanks in advance.
Wednesday I hope, we have other things in the pipeline.
Thank you. I understand.
Hi, as promised. The header is called X-NoResolveLanguages
Thank you.
Where can I find this header? And is it possible to see if the language is available per item?
It is a normal Http header.
Excellent. This is exactly what I need. Thanks, Sebastian. You are brilliant!
And thanks Google for pointing me here. Maybe this should be highlighted in the docs. Maybe it’s there. At least I didn’t see it.
