I want to have a postman request to get all contents without authentication
How can I disable authentication from contentscontroller?
You can remove the attributes: https://github.com/Squidex/squidex/blob/master/src/Squidex/Areas/Api/Controllers/Contents/ContentsController.cs#L62
After removing ApiPremission attribute, I get “404 Not Found”.
Then try to add [AllowAnonmyous]
