I have set the rules for my articles to send data to Algolia index when
`event.type == 'Published' || event.type == 'Updated'`
When a new article is published, the data fields sends to Algolia index.
But when I delete an article in the Squidex cms, the data in the Algolia index does not remove automatically.
What do I need to setup to remove the data in Algolia when an article is deleted?
Thanks in advanced.
Because you told the rule action to handle only these two events. I would add Unpublished as well.
See in code: Delete content in Squidex not updated in Algolia
I have updated the rule to this:
event.type == 'Published' || event.type == 'Updated' || event.type == 'Unpublished'
but it still not working. Something else I need to do?
If you delete an item I would also add Delete or you just leave it blank to handle all events.
Leaving it blank works fine. Thanks
