Debugging not working of dynamically loaded DLLs
Hi, I was trying to build FTPAssetStore in Squidex.Extensions project. but however, I can not debug it.
After I did some research.
https://developercommunity.visualstudio.com/content/problem/105769/debugging-not-working-of-dynamically-loaded-dlls-a.html
Do you get the same issue as well?
I will test it, have not needed it yet.
Seems to work with VS 2019
Okay, i will test it on VS2019. Thanks
