DateTime Field Filtering Issue When Retrieving Previous Day Records
We would like to confirm whether the following filter is the correct approach for retrieving all records from the previous day. FirstPublished is datetime field.
Our scheduler runs daily at 5:00 AM UTC. For example, when the scheduler runs on 30 September 2026, we intend to retrieve all content published on 29 September 2026.
We are currently using the following filter:
(data/FirstPublished/iv gt 2026-09-29T00:00:00Z and data/FirstPublished/iv lt 2026-09-30T00:00:00Z)
Could you please confirm whether this is the correct filter to retrieve all records published on 29 September 2026?
We would also like to clarify:
  • Whether this filter is expected to return all records published on 29 September 2026.
  • Whether there are any known limitations or timezone considerations when filtering DateTime fields.
  • Whether we should be using inclusive operators (ge, le) instead of exclusive operators (gt, lt) for this scenario.
  • Is this the recommended approach for retrieving all records from a specific UTC day?
  • We would like to know whether Squidex provides any built-in functionality to filter using the date portion only of a DateTime field. (eg FirstPublished = 2026-09-29)
Our goal is to retrieve all records published on a specific day without having to manually construct DateTime boundaries for that day.
I would use greater-equals for the first comparison but in general it is correct.
Thanks for the clarification.
We’ll update the query to:
(data/FirstPublished/iv ge 2026-09-29T00:00:00Z and data/FirstPublished/iv lt 2026-09-30T00:00:00Z)
Just to confirm, is this the recommended and preferred approach for retrieving all records published on a specific UTC day?
Also, does Squidex provide any built-in way to perform a date-only comparison on a DateTime field? For example, is there any function or operator that would allow us to compare only the date portion of FirstPublished (e.g., 2026-09-29) without explicitly specifying a start and end DateTime range?
If such functionality exists, could you provide an example? Otherwise, we’ll continue using the range-based approach above.
Internally dates and datetimes are always stored as UTC date-times. I guess we could improve the filter system to transform these queries to a range query, but right now it is not possible.
