Custom order for schemas
This should work if you move the schema in the Schema tab
Drag and drop to move the schema in the Schema tab.
Version: 7.21.0
move frequently used schemas to the top, but the problem is that dragging does not work and the order does not change.
I’m not sure if this is an implementation omission or a bug, but it leaves an issue.
Schemas cannot be sorted, only moved to other categories. They are always sorted by name. I have changed it to a feature request.
