I’m working on the design of a new app and have realized that some of my schemas should really be components. (I realize that I can use them as components, but I want them to be true components so that content people can’t create records in those schemas.)
I could clone them, but I really want to keep their current names. I thought perhaps I could use the CLI to export the schema, delete the live version, then (somehow) sync it back in as a component. But there doesn’t seem to be anything inside the schema’s json that identifies it as a component, and I can’t find a CLI command or option to identify it as a component when I sync.
Any tips on this would be greatly appreciated. I’d rather not have to recreate them manually as components.
Thanks!
