- [x] Bug report
I have created a schema (Single content) and added components field (with four text fields and one assets field) to add items in an array, for first two items it successfully updates the content but when I add third one it throws error “Failed to update content. Please reload.” and “Failed to load resource: the server responded with a status of 502” in console
It should update content with more than two items
- [x] Self hosted with Google Kubernetes engine
Version: [6.8.0]
- [x] Chrome (desktop)
this is the output in console
Thank you for your response.
We are using ingress and I have checked the logs, this is what I am getting in logs
Exception type: System.TimeoutException
“message”: “Response did not arrive on time in 00:00:30 for message: Request S127.0.0.1:11111:396565635*cli/7750379f@62bd0599-\u003ES127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f@6d0160ad InvokeMethodRequest Squidex.Domain.Apps.Entities.Contents.DomainObject.IContentGrain:ExecuteAsync #314266. Last known status is IsExecuting: False, IsWaiting: True, Diagnostics: [[Activation: S127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f-0x4DA69EED@6d0160ad #GrainType=Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain Placement=RandomPlacement State=Valid NonReentrancyQueueSize=3 EnqueuedOnDispatcher=0 InFlightCount=1 NumRunning=1 IdlenessTimeSpan=01:13:59.4230651 CollectionAgeLimit=02:00:00], TaskScheduler status: WorkItemGroup:Name=[Activation: S127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f@6d0160ad #GrainType=Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain Placement=RandomPlacement State=Valid],WorkGroupStatus=Waiting. Currently QueuedWorkItems=0; Total Enqueued=76; Total processed=76; Quantum expirations=0; TaskRunner=ActivationTaskScheduler-187:Queued=0; Detailed context=\u003C[Activation: S127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f-0x4DA69EED@6d0160ad #GrainType=Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain Placement=RandomPlacement State=Valid NonReentrancyQueueSize=3 EnqueuedOnDispatcher=0 InFlightCount=1 NumRunning=1 IdlenessTimeSpan=01:13:59.4230734 CollectionAgeLimit=02:00:00 CurrentlyExecuting=Request S127.0.0.1:11111:396565635*cli/7750379f@62bd0599-\u003ES127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f@6d0160ad InvokeMethodRequest Squidex.Domain.Apps.Entities.Contents.DomainObject.IContentGrain:ExecuteAsync #287768]\u003E, Message Request S127.0.0.1:11111:396565635*cli/7750379f@62bd0599-\u003ES127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f@6d0160ad InvokeMethodRequest Squidex.Domain.Apps.Entities.Contents.DomainObject.IContentGrain:ExecuteAsync #287768 was has been executing for 01:13:46.0736093., Message Request S127.0.0.1:11111:396565635*cli/7750379f@62bd0599-\u003ES127.0.0.1:11111:396565635*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f@6d0160ad InvokeMethodRequest Squidex.Domain.Apps.Entities.Contents.DomainObject.IContentGrain:ExecuteAsync #314266 has been enqueued on the target grain for 00:00:30.3902860 and is currently position 3 in queue for processing.]. Target History is: \u003CS127.0.0.1:11111:396565635:*grn/Squidex.Domain.Apps.Entities.Contents.DomainObject.ContentDomainObjectGrain/0\u002B05f18c1c-9ae5-4f90-873c-29d427f96a07--67b315a8-8976-45ec-880e-e26c0123f35f:@6d0160ad\u003E.”
Can you try to make an upgrade?. I think I know what the problem is.
We upgraded version from 6.8 to 7.0 but that resulted in all the content and schema disappearing from the apps. Also when when we tried restoring back ups that we took before up-gradation, the restoration didn’t worked as well.
7.0 is still on RC and not meant for production. I mean 6.9 or 6.10.
Sure, I will try with 6.10 and will keep you posted.
Thanks
Hi @Sebastian,
Thank you so much
, After upgrading to 6.10 everything is working properly.
