Hi we are considering using CDN in front of assets in Squidex, but lacking to figure out what best practice is. I’m used to use public-cache, but seems like Squidex do it in another way?
Could you share how your cloud setup is configured?
What do you mean with public-cache? Usually the assets supports etags and you can also configure the cache time in your requests:
https://docs.squidex.io/02-documentation/developer-guides/api-overview/assets-api#how-caching-works
See the note about the cache query string.
