- [x] Bug report
Sending a cache header when requesting assets does not set Cache-Control header.
According to the documentation sending a cache header should result in the response containing a Cache-Control header in the response with maxAge set to the sent cache value.
But it looks like Cloudflare swallows this and the Cache-Control header isn’t in the response. Is this feature still supposed to be supported in the cloud version of Squidex / Squidex instances with a CDN?
- Request an asset on squidex cloud and set the
cacheheader - Observe the response: it doesn’t contain the
Cache-Controlheader
- [x] Cloud version
Version: N/A
- [ ] Chrome (desktop)
- [x] Android native client (with Apollo graphQL library)
