- [x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [x ] Bug report
We are currently using the ClientLibrary create and get content from our app in our C# solution.
Some times, multiple times a day we a 500 exception when using the library. We use the following code:
private async Task<string> GetSiteId(string siteHost)
var sites = _squidexClient.CreateContentsClient<Site, SiteData>("sites");
var resp = await sites.GetAsync(new ContentQuery
Filter = $"data/host/iv eq '{siteHost}'"
var siteId = "";
if (resp.Total > 0)
siteId = resp.Items[0].Id;
return siteId;
This works fine and we can get the content normally. But sometimes we get the following exception: https://pastebin.com/fMbvEa57 (Sorry for the danish language)
We have some retry functionality, and 9/10 times it works the second time.
What I could find about the 995 error is that the error comes since you try to continue read from the socket when it has most likely been closed.
I expect it to succeed for every request with no exceptions thrown
- [x ] Self hosted with docker
Version: 5.2.0
- [ ] Chrome (desktop)
