ClientLibrary Localization
i have a problem if i add localizable items to a schema.
If i load the data via Postman with X-Languages and X-Flatten Header everything works as expected, but if i load the data via the ClientLibrary i got an exception:
An unhandled exception occurred while processing the request.
JsonSerializationException: Property must have a invariant language property.
Squidex.ClientLibrary.InvariantConverter.ReadJson(JsonReader reader, Type objectType, object existingValue, JsonSerializer serializer)
My Code:
public async Task<List<Page>> GetPagesAsync()
            var context = QueryContext.Default.WithLanguages("en").Flatten();
            var pages = await this.pagesClient.GetAsync(context: context);
            return pages.Items;
Thank you,
Patrick
at the moment the InvariantConverter always requires the following structure for each property:
   "iv": "Foo"
You can just remove the converter from your properties.
it works now, thanks!
I have the same problem. I become the Error: JsonSerializationException: Property must have a invariant language property.
My Structur is:.
“data”: {
* "header":{
  * "en":[],
  * "de-DE":[
      * "Name": "string",
      * "Text": "stringstringstringst",
      * "Image":[],
      * "Slug": "stringstri",
      * "Tags":[]}],
My cs - File:
 public sealed class  PostData
        public Header[] Header { get; set; }
        public string Text { get; set; }
    public sealed class Header
        public string Name{ get; set; }
MY API:
      var query = new ODataQuery { Skip = page * pageSize, Top = pageSize };
      var context = QueryContext.Default.WithLanguages("de").Flatten();
`var posts = await postsClient.GetAsync(query, context);`
How should the class structure look like?
Header needs to be a Dictionary<Header[]> Header { get; set; }
Sorry, I meant Dictionary<string, header[]> … the key is the language the value is the field value.
JsonSerializationException: Cannot deserialize the current JSON array (e.g. [1,2,3]) into type ‘System.Collections.Generic.Dictionary`2[System.String,Models.Header[]]’ because the type requires a JSON object (e.g. {“name”:“value”}) to deserialize correctly.
To fix this error either change the JSON to a JSON object (e.g. {“name”:“value”}) or change the deserialized type to an array or a type that implements a collection interface (e.g. ICollection, IList) like List that can be deserialized from a JSON array. JsonArrayAttribute can also be added to the type to force it to deserialize from a JSON array
Unfortunately, that’s still not possible, I had already tried that. Is there possibly still another error? I have created an array of languages in the schema
Dictionary<string, Header> Header Does not work either
i can only write 3 replays. to the last comment: InvariantConverter
hi, I had meanwhile removed that. if I have it in the message comes:
Sorry, you have to remove the InvariantConverter then.
I have removed the limitation. Can you show me your data class again?
Hi my Code . I use your Blogsample with changes:
 public sealed class PostsVM
            public List<Post> Posts { get; set; }
            public long Total { get; set; }
            public long Page { get; set; }
            public long PageSize { get; set; }
public sealed class Post : SquidexEntityBase<PostData>
        public   Dictionary<string, Header> Header  { get; set; }
        public string Previewtext { get; set; }
Abfrage:
 public async Task<(long Total, List<Post> Posts)> GetPostsAsync(int page = 0, int pageSize = 3)
            return (posts.Total, posts.Items);
in Squidex all root level fields are objects,
e.g.
for non localized fields
  "iv": "My-Value"
for localized fields
  "en": "My English Value",
  "de": "My English Value"
But invariant fields are annoying to handle in C#, therefore the InvariantConverter.
But they must not be applied to nested fields, because nested fields have the following structure:
  "iv": [{
    "nested": "My Nested Value"
,Now I remove all invariants in the Header. I still have the error. how would that be the solution?
It should be
        public   Dictionary<string, Header[]> Header  { get; set; }
Hi, thanks for the help. Unfortunately that did not work.
I also tried something.
With:
public Header[] Header {get; set; }
it works now.
