- [x] Bug report
When having an empty invariant nested field on a squidex, the api will return an empty object. When having the following attribute
the code will break on the check to see if it’s actually an IV field.
Example of the field in squidex
"name": "colors",
"properties": {
"isRequired": false,
"isRequiredOnPublish": false,
"isHalfWidth": false,
"fieldType": "Array",
"minItems": 0,
"maxItems": 3,
"label": "Colors",
"hints": "Themed Colours. Will alternate between"
"isLocked": false,
"isHidden": false,
"isDisabled": false,
"partitioning": "invariant",
"nested": [
"name": "color",
"properties": {
"isRequired": true,
"isHalfWidth": true,
"fieldType": "String",
"editor": "Dropdown",
"inlineEditable": false,
"isUnique": false,
"defaultValue": "Primary",
"allowedValues": [
"Primary",
"Secondary",
"Tertiary",
"Quaternary"
"contentType": "Unspecified",
"label": "Color",
"hints": "The color of the card",
"placeholder": ""
"isLocked": false,
"isHidden": false,
"isDisabled": false
example response
"id": "b78c3e87-498a-4aff-9cd9-4b3f88bd7b18",
"createdBy": "...",
"lastModifiedBy": "...",
"data": {
"fullWidth": {
"iv": true
"centerText": {
"iv": true
"colorGradient": {
"iv": false
"colors": {},
"title": {
"nl": "..."
"description": {
"nl": "..."
"cards": {
"iv": [
"552030..9f2",
"77aa67..e4",
"3b9520..ab"
"deletedDate": {
"iv": null
"publishedDate": {
"iv": "2021-03-30T13:02:46Z"
"created": "2021-03-30T13:02:46Z",
"lastModified": "2021-05-01T22:48:49Z",
"status": "Published",
"statusColor": "#4bb958",
"schemaName": "cardsection",
"schemaDisplayName": "Cards",
"version": 3,
"_links": {
"self": {
"href": "...",
"method": "GET"
"previous": {
"href": "...",
"method": "GET"
"draft/create": {
"href": "...",
"method": "POST"
"delete": {
"href": "...",
"method": "DELETE"
As you can see the "colors": {}, is just an empty object.
I think it would be beneficial if squidex would send the following object for invariant nested fields
"colors":{
"iv" : []
On first glimpse this would allow the ClientLibrary converter not fall over the empty object & insert an ‘empty’ collection into the correct field.
Alternatively an null could also be set, for a null value for the collection instead of an empty collection.
- Create an scheme with an nested object like the one included
- Create content from said scheme, but don´t add any nested objects
- Create a C# model to work with the client library, and use the invariant converter
- Request the data
- [x] Cloud version
- [ ] Chrome (desktop)
- [x] Vivaldi (Chromium)
