- [ X ] Documentation issue or request
I’ve tried to install certs at https://github.com/Squidex/squidex/tree/master/dev with no luck on macOS.
Tried drag and drop on my keychain and nothing happens. Also tried dragging the localhost cert from chrome (From “Not Secure” warning) and adding it to keychain access with no success.
To install the localhost dev cert to be able to work with the CLI.
I ran successfully the following command:
./sq config add atlas atlas:default (token) -u https://localhost/
After this I try to connect to it and work with my content, I get the following error:
ERROR: System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure: RemoteCertificateNameMismatch, RemoteCertificateChainErrors at System.Net.Security.SslStream.SendAuthResetSignal(ProtocolToken message, ExceptionDispatchInfo exception) at System.Net.Security.SslStream.ForceAuthenticationAsync[TIOAdapter](TIOAdapter adapter, Boolean receiveFirst, Byte[] reAuthenticationData, Boolean isApm) at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Boolean async, Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Boolean async, Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.CreateHttp11ConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.GetHttpConnectionAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken) at Squidex.ClientLibrary.Configuration.Authenticator.GetBearerTokenAsync() at Squidex.ClientLibrary.Configuration.CachingAuthenticator.GetBearerTokenAsync() at Squidex.ClientLibrary.Utils.AuthenticatingHttpMessageHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken) at System.Net.Http.HttpClient.SendAsyncCore(HttpRequestMessage request, HttpCompletionOption completionOption, Boolean async, Boolean emitTelemetryStartStop, CancellationToken cancellationToken) at Squidex.ClientLibrary.Management.SchemasClient.GetSchemasAsync(String app, CancellationToken cancellationToken) at Squidex.CLI.Commands.App.Schemas.List(ListArguments arguments) at CommandDotNet.Execution.InvocationResultExtensions.GetResultCodeAsync(Object value) at CommandDotNet.AppRunner.HandleException(Exception ex, IConsole console, CommandContext commandContext) at CommandDotNet.AppRunner.Run(String[] args) at Squidex.CLI.Program.Main(String[] args)
- [ X ] Self hosted with docker
Version: 5.6.0.0
- [ ] Chrome (desktop)
Running on macOS Catalina
