- Bug report
- Performance issue
When executing CLI command “sq schemas sync {schema-name}” whilst trying to migrate schema definitions from one self-hosted instance of Squidex to another I noticed that any schema that included a component reference was being migrated but losing that component reference.
Component references in exported schema definitions (json) would be respected and recreated, looking up schema ID from the referenced component name.
As stated above.
Non-prod.
App Name: the-event-app
- Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: CLI version 13.7
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
I took a look at the code directly, and got it working by changing the Squidex.CLI.Commands.Models.SchemaWithRefsExtensions.AdjustReferences method to the below. But I am not set up to raise a PR and not very aware of any potential wider implications.
public static SchemaWithRefs<T> AdjustReferences<T>(this SchemaWithRefs<T> target, ICollection<SchemaDto> allSchemas) where T : UpsertSchemaDto
List<string>? Handle(List<string>? schemaIds)
if (schemaIds?.Count > 0)
var newSchemaIds = schemaIds.ToList();
var i = 0;
foreach (var schemaId in schemaIds)
if (target.ReferencedSchemas.TryGetValue(schemaId, out var name))
var referenced = allSchemas.FirstOrDefault(x => x.Name == name);
if (referenced != null)
newSchemaIds[i] = referenced.Id;
i++;
return newSchemaIds;
return null;
foreach (var field in target.Schema.Fields.OrEmpty())
switch (field.Properties)
case ReferencesFieldPropertiesDto reference:
reference.SchemaIds = Handle(reference.SchemaIds);
break;
case ComponentsFieldPropertiesDto componentsReference:
componentsReference.SchemaIds = Handle(componentsReference.SchemaIds);
break;
case ComponentFieldPropertiesDto componentReference:
componentReference.SchemaIds = Handle(componentReference.SchemaIds);
break;
foreach (var nested in field.Nested.OrEmpty())
switch (nested.Properties)
break;
break;
break;
return target;
