- [ X] Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
- [ X] Used code blocks with ``` to format my code examples like JSON or logs properly.
- [X ] Regression (a behavior that stopped working in a new release)
- Bug report
- Performance issue
I recently upgraded my self-hosted Squidex instance from 7.15 to 7.23. Before the upgrade, I followed the recommended steps:
- Set
CONTENTS__OPTIMIZEFORSELFHOSTING=true. - Set
REBUILD__CONTENTS=true. - Removed the rebuild variable once finished.
The UI seems to work fine, but I am encountering critical issues with the Squidex CLI when managing schemas.
Environment:
- Squidex Server Version: 7.23
- CLI Version: 13.13.0
- OS: Windows (running via PowerShell)
The Issues:
- Schema Import failing silently:
- I performed a
sync checkout. - I manually added a new schema JSON file (copied from another project) into the checkout folder.
- I ran the sync command, and although no errors were reported, the schema was not imported.
- Empty Schema on Update:
- When I tried to update an existing schema using the JSON file obtained from a
checkout, the CLI deleted all existing fields, leaving an empty schema structure.
- Workaround behavior:
- I noticed that if I run
schemas sync --schema <name>, it generates a JSON file containing the App ID, Version, and API calls (PUT, GET, etc.). If I manually fill that specific file with my fields and run the command again, the import works.
Observations:
It seems like the standard sync flow is not correctly mapping the fields during the “in” operation after the 7.23 upgrade, or there is a mismatch in how PowerShell handles the JSON encoding/structure with this specific version.
Am I missing a specific configuration for the CLI or a breaking change in the JSON schema structure for 7.23?
- [ X] Self hosted with docker
- Self hosted with IIS
- Cloud version
Version: 7.23
- [ X] Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
