- [x] Bug report
Dragging a schema to change the order (above or below another schema) does not do anything, the schema that is being dragged stays in the same spot/order.
Dragging a schema above or below another schema should change the visual represented order of the schema’s.
In the Squidex front end, drag a schema and try to place it above or below another schema.
Nothing changes and the schema’s stay in the same order.
- [x] Cloud version
Version: Current cloud version
- [x] Chrome (desktop)
- [x] Firefox
- [x] Safari (desktop)
