- [x] Checked the logs and have provided uploaded a log file and provided a link because I found something suspicious there.
- [x] Bug report
I tried generating the c# client from the swagger client cloud version and I found a strange behavoir. After the last generation, that has been perfomed some months ago, the properties of my schema were flagged as “Required = Newtonsoft.Json.Required.Defaul”, now instead with “Required = Newtonsoft.Json.Required.DisallowNull”. With this modification when I try to deserialize some content that do not have some property valorized I get a DeserilizationException. Since I do not changed the schemas, this must be some bug in the swagger.json definition.
Here a comparison between the two version of the generated code of a variable of one of my classes:
#OLD
[Newtonsoft.Json.JsonProperty(“FooterContentsMobile”, Required = Newtonsoft.Json.Required.Default, NullValueHandling = Newtonsoft.Json.NullValueHandling.Ignore)]
public ChannelconfigFooterContentsMobileProperty FooterContentsMobile { get; set; }
#NEW
[Newtonsoft.Json.JsonProperty(“CustomerModelMandatoryFields”, Required = Newtonsoft.Json.Required.DisallowNull, NullValueHandling = Newtonsoft.Json.NullValueHandling.Ignore)]
public ChannelconfigCustomerModelMandatoryFieldsProperty CustomerModelMandatoryFields { get; set; }
If in the schema configuration the field is not mandatory, the generated client with swagger must handle the null value
- [X] Cloud version
- [X] Chrome (desktop)
