Cant login to the squidex when im using not authorized SSL cert ( like a self-signed - unknown CA ).
Login to the squidex despite noCA SSL cert. ( If its possible. )
self-sgned SSL cert.
- [x] Self hosted with docker
Version: 5.0.0
- [x] Chrome (desktop)
- [x] Firefox
Is it possible to login despite corrupted cert? If yes, what i should to set in squidex?
