I try to apply the following query to the component pagemeta:
var queryContext = QueryContext.Default.WithLanguages(CurrentLanguage);
var cmsPage = await PageClient.GetAsync(
query: new ContentQuery { Filter = $"data/pagemeta/{CurrentLanguage}/slug/iv eq '{page}'" },
context: queryContext,
ct: cancellationToken);
and I get an exception:
OData operation is not supported for query: ?$filter=data/pagemeta/en/slug/iv%20eq%20’/’
meanwhile if I move the slug outside of thepagemetacomponent everything is fine…
Being able to filter inside pagemeta component
- [x] Self hosted with docker
Version: [4.8.1]
- [ ] Chrome (desktop)
- [x] Firefox
