- [x] Checked the logs and have provided the logs if I found something suspicious there
The log show the request to the /api/restore endpoint
Calls to BackupsClient.GetRestoreJobAsync returns nothing
Within SquidexClient GetRestoreJobAsync method in “generated” the following call throws an exception that is not caught. When the SquidexClient code is changed to catch the exception is shows a 404 page not found for /api/restore:
await client_.SendAsync(request_, System.Net.Http.HttpCompletionOption.ResponseHeadersRead, cancellationToken).ConfigureAwait(false);
The method should return the existing restore jobs or an empty set
- [x] Self hosted with other version
Server 4.4
