AWS DocumentDB as backend
We’re evaluating AWS DocumentDB as the backend for Squidex.
I see that the configuration supports a derivate value of DocumentDb (alongside MongoDB, FerretDb, CosmosDb) under both eventStore and store, and that 7.21+ mentioned DocumentDB support in the context of the FerretDB work.
Is AWS DocumentDB currently considered supported / recommended for production? Are there any known limitations or required extra configuration (TLS certificates, index naming, connection options, etc.) beyond setting derivate=DocumentDb?
