AWS AMI deprecated? Alternatives?
The Squidex docs explains how to host on AWS
https://docs.squidex.io/01-getting-started/installation/platforms/install-on-aws
I click the first button, which leads to the AWS AMI which says “This version has been removed and is no longer available to new customers.”
https://aws.amazon.com/marketplace/pp/prodview-zvohj6i2bye7w
Is this normal? And if this is deprecated, is there a recommended solution for hosting Squidex on AWS?
Thanks
I had no idea that it is not available anymore. But honestly it has not been used a lot.
Most users either host Squidex with…
  1. Container hosting (https://aws.amazon.com/de/getting-started/hands-on/deploy-docker-containers/)
  2. Kubernetes
It really depends on your infrastructure. If you have kubernetes already, I would go for that. There is helm chart squidex7 for that.
