- [x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [x ] Documentation issue or request
- [ x] Self hosted with docker
- [x ] Chrome (desktop)
Hi Sebastian
I am trying set a nullable GenericRecord in Avro Schema of Kafka. The problem is that when value is available, it adds the extra key.
Example
Avro Schema
"name": "country",
"type": ["null", {
"name": "country",
"type": "record",
"fields": [
"name": "id",
"type": "string"
"name": "type",
"type": "string"
Payload
"country":
{% if country.id != null %}
"id" : "{{country.id}}",
"type" : "country"
{% else %} "",
{% endif %}
**Result - for null country **
"country": null
**Result - for none null country **
"country": {
"namespace.country": {
"id": "1",
"type": "Italy"}
How can I get rid of “namespace.country” ?
I want …
"country": {
"id": "1",
"type": "Italy"}
Thanks in advance
