- [ ] Checked the logs and have provided the logs if I found something suspicious there
- [ X ] Community Support Request
Go to https://domainname/api/content/app/swagger/v1/swagger.json
Download
Use swagger with Autorest :
autorest --v3 --csharp --namespace=Fileshare.API --add-credentials --input-file=“swagger.json” --output-folder=“temp” --debug --verbose
AutoRest code generation utility [cli version: 3.0.6163; node: v12.14.1, max-memory: 8192 gb]
© 2018 Microsoft Corporation.
Output:
Error parsing swagger file. Error converting value False to type ‘AutoRest.Modeler.Model.Schema’. Path ‘components.schemas.UsersDto.additionalProperties’, line 1, position 352280.
FATAL: AutoRest.Core.Logging.CodeGenerationException: Error parsing swagger file. Error converting value False to type ‘AutoRest.Modeler.Model.Schema’. Path ‘components.schemas.UsersDto.additionalProperties’, line 1, position 352280.
- [ X ] Self hosted with IIS
Version: [4.1.0.0]
- [ X ] Chrome (desktop)
Does anyone have any experience while using Autorest and the Squidex API swagger ?
I can’t manage to generate the client classes by any form… Used Nswag also without success, the generation finalizes but the output .cs file has alot of compile errors (base classes defined has abstract for example) and personally I prefer the AutoRest implementation of the clients.
