Autopublish referenced content
Hello,
I want to ask if there is a way how to “autopublish” referenced content.
Example:
I have “Article” and “Author”.
Article reference it’s author.
If I didn’t published author but did published article then I have published article without published author.
Is there a way how to publish author if the first article is published for this author?
Not yet. The only option I see is to create a workflow where Published is the default state. This could work.
Thank you for reply.
How can this be done? I don’t see an option in workflows to select Published as the default?
When you hover a workflow step you should see small arrow on the left. Click that to change the initial state.
I see that on other steps. But not on the ‘Published’ state
Sorry, then it is not possible yet. To be hones I don’t remember the reason.
Hello,
I am in a similar situation. However, I would like to just warn the user that the article he is publishing makes reference to unpublished items.
Is there any way to make this notification?
Unfortunately not, I am sorry.
